Had our pool/spa built in 2003 with a Hayward H400IDL heater that recently started knocking with a broken internal bypass valve baffle. Upon removing the header (and broken baffle pieces) I discovered that there were no valve parts installed inside. No valve, no guide shaft, and no spring. The only other loose part inside was the flow control thermostat.
Any guesses as to why these parts are missing? Could it be a manufacturing mistake? Corrosion and disintegration? The heater has always worked flawlessly and there are no unusual sounds or flow problems when pool and pump are operating. The heater has never been serviced since installation.
I bought a rebuild kit and am planning to install all the parts as per the diagram.
