PF Electrical supply wiring error
This code will display if 120V polarity is reversed, low voltage is detected, or if the ground path is not sufficient. Reset is immediate after error is corrected.
Electrical connections:
The heater is equipped with a hot surface ignition control system that automatically lights the burners.
An external power supply is required to power the control system.
The electrical specifications for this heater are 120/240VAC, 60Hz, 1-phase, 5.5A maximum current.
It is recommended that circuit protection for the heater circuit be rated at 15 Amperes.
The heater is shipped from the factory wired for use with 240VAC, 60 Hz field power supply.
To convert the heater to 120VAC, 60 Hz operation remove the 240VAC voltage selector jumper from the ignition control board and replace it with the 120VAC jumper.
These jumpers are tie-wrapped together and are located on the fuse board.
See Figure 21 for location of the fuse board.
