Hayward / Goldline Aquarite Power & Chlorinating Lights not staying on
NYAVGUY
64
New York
My in-laws SWG is not working currently. It appears to be an issue with the controller which there are numerous discussion on, but I couldn't find this exact issue. Let me know if I need to get out the volt meter and take some readings, or if someone can suggest what parts I should buy to fix it.
I took a video of the issue:
VID_20180923_165006 - Streamable
Water Chemistry - used TF-100 test kit:
FC-14 (there was some algae growing when I found it at 0, so it is coming down from being shocked up to 20)
CC - 0
PH-7.5
TA-80
CH-275 (gunite pool)
CYA-50
Salt-3200 (tested with Taylor drop kit)
