So I cleaned my Hayward cartridge filter a couple weeks ago, put everything back together. Tighten the band to 150inch pounds as recommended my the mfg. started up and noticed at prime I am getting a slight dripping from the filter. Tighten just a hair more it stopped.
Well tonight I added acid so I turned the pump on, well 3 hours later my wife asked why is the pump running on high
. For whatever reason one it primed it stared at high speed vs dropping to 30%.
When over to the EQ pad, it’s wet on the pad so I am guessing high speed just mad it leak more.
So tomorrow I will pull the lid off and reset the o ring, it’s only 1 year old
Do I need to drain the entire filter bottom or can I just depressurize and drain just below the mid section to clean and o ring again. Mgf says no lube, so I will try it again.
