I have a Hayward EC75a DE filter mounted on the Hayward base as seen in the link below. I would like to change my setup so that I can easily use the pump to bypass the filter and vacuum to waste. This would be useful when opening the pool or when I need to lower the water level due to rain. My understanding is that the backwash drain on the filter is only for backwashing the system and it is bad for the filter fingers to use it to vacuum to waste. Why Hayward does not have a bypass valve built in is beyond me.
Currently I have to manually disconnect the elbow piece from the pump to the filter and use a clamp to attach some tubing to the top of the pump. I then use a utility pump to pump out excess rain water from the pool. This takes time and is not convenient. I would like to attach some type of valve that allows me to easily switch between the filter and a hose that goes to waste. A utility pump would not be needed. The issue is that there is very little space to work with to put in a bypass valve. I would appreciate any creative ideas or links to possible valves and I have to think I am not the only person with this problem.
https://hayward-pool-assets.com/assets/images/pools/products/large/PerflexSystem.jpg?fromCDN=true
