Hello,
I have read all of the great threads on troubleshooting my aquarite and I have installed a new T-Cell 9 yet have no salt generation...
Reading
0
74
31.9
0.00
76P(chages if I turn the dial)
-0
AL-5 I do not have automation to the RS485 and could not change this to AL-0
r1.59
t-9
0
PCB is blue model G1-0660120-1 on PCBA itself
white sticker G1-011056G-1
Troubleshooting done so far:
I have tested the transformer primary winding and resistance is OK
I have ohmed out the rectifiers forward and reverse with diode mode on my meter and all ok
20A fuse OK
I get 31.9 VDC on the red to black transformer secondary which matches the display
I get 12.2 VAC from orange pin to green ground on box as shown in troubleshooting manual - OK
I have 5V on pin 2-4 and pin 4 to gnd on the control/display pins and re-set the board
I have opened the PCB and there are no burned or cold solder joints
Have looked at and measured across the thermistor and it is fine (My model has the K4 across the thermistor)
Get 24V on the K1 and K2 relay tops
Have 5V on the T cell thermistor pin
T cell output pins 1-2, 3-4 are 0 V to gnd as no salt.
I cannot change from AL-5 to AL-0 and I do not have any automation connected to the RS485...
at wits end here...
Appreciate any advise other than to replace a recent clean PCB.
Thanks
Reading
0
74
31.9
0.00
-0
r1.59
t-9
0
20A fuse OK
at wits end here...
Thanks
