Hey folks, this is a long post with lots of questions. Bear with me.
I'm a little overwhelmed with choices at the moment.
I've been going round and round on options for changing/upgrading my equipment pad. Currently it's ye-olde single speed pump and sand filter. I have been looking at various options to a) add a SWCG, a-1) maybe add acid injection b) replace the filter with a cartridge filter, c) replace the pump with a VSP, and maybe d) replace the halogen light.
Topic 1: Automation or not?
What's the current state of automation? Pool automation still seems like it's either clunky and antiquated, or astronomically expensive for anything resembling "high-tech". I do not have anything fancy... no water features, no spa, etc., and my budget is "I'd like to accomplish this for as little as possible" considering I'm embarking on a $10k pebble and deck resurfacing. My investigation into automation started because I was looking at replacing the old halogen light with a LED/color changing light. Most of them are controlled by flipping the switch, and I don't want to sit out there flipping the switch 20 or 300,000 times if I want to get a particular effect. I saw that there was a solution with Hayward lights that can be controlled with the Aqua Plus that would enable more color choices and dimmer/pattern control of the light that is not possible with just using switch-flipping.
I was pretty much settled on getting a simple Aqua Rite AQR15 for the SWCG, going rate is around $875 or so. However, I then fell onto the Aqua Plus / Pro Logic option which is around $1200 from INYO (Goldline Controls Pro Logic PLP4 Control, Chlorinator Pool or Spa Only - PLP4PACK - INYOPools.com). So, about a $325 upcharge from the basic SWCG to the one with automation. That seems reasonable. But, I know that now I have to start adding all kinds of gadgets and modules to make the automation useful. Is it worth the cost if my needs/wants are:
- SWCG
- VS pump
- LED light control
- Possible acid injection ?
Since I don't have any water features or a spa I don't need to worry about valves or anything, this would merely be for automating my chemistry if feasible and having better/more control of the lighting, from a remote (or a smart phone would be much nicer...) rather than switch-flipping in the pool panel box.
Subquestion -- what is the difference between the Aqua Plus and the Pro Logic?
Hayward Aqua Plus 40K Gallon Control and Chlorinator (PL-PLUS) - INYOPools.com
Topic 2: Pump
Again, I was pretty much settled on the Pentair SuperFlo 342001 as my needs do not require a "big boy" VS pump. This pump can be had for the low to mid $600's.
I was tempted by the chinese pumps... Splash/Blue Torrent/whatever rebranding varies from 399 down to I think I saw 319 on ebay. I realize it's a gamble, but, hey, what isn't these days? However, if I am going to go with any kind of automation or integration, I don't think this would play well.
I wasn't considering any Hayward pumps until I started looking at the Hayward automation. Do I need a Hayward pump or will the Aqua Plus play nice with the Pentair pump?
To further complicate things, and circling back to automation, I just learned of the new Hayward Omni pumps that have what looks like much more up-to-date tech for automation built in. I think I would be looking at the MaxFlo 500 Omni, though it's really hard to distinguish an actual difference between the MaxFlo 500 Omni and the Super Pump 700 Omni. These are pro-only models, so I would be paying a fair bit more than if I sourced the parts online. Is this Omni automation sufficient, or does it lack in some appreciable way, like it doesn't do SWCG/Acid/etc. control?
Topic 3: Filter
This is an easy one... I was decided on the Pentair CCP420 cartridge, but one of the guys who gave me an estimate for my pebble/deck resurfacing "strongly" recommended the 520. I estimate I have around 15-18k gallons... so 420 or 520?
Topic 4: Acid or CO2?
I was interested in maybe adding acid injection... stenner pump or something that integrates with the Hayward Sense & Detect if I went that route. They also promote CO2 as an option, but it seems to me that sticking with acid would be best. I saw a few posts where this was discussed but I couldn't really glean a why I would / why I wouldn't bottom line from it. Thoughts?
Forgive the pun, but my head is swimming in options.
With all this laid out... am I on the right track? Am I so far down the rabbit hole that it's hopeless? Do you have a better suggestion or direction that I could take to accomplish what I'm looking to do? I'm not married to the Hayward idea, it's just what I found to be semi-approachable from my experience level.
This could be a "what would YOU do" question, or a "what do you suggest *I* do" question, or just can you help me narrow down my choices and come to a conclusion that strikes a balance between my wants and trying to minimize budget? I don't mind spending a little bit, if I'm getting the value for the money spent.
Thanks, and sorry for throwing 10,000 questions into a single post. I thought about breaking it up into multiple posts, but they all kind of come back to each other because my choices in one area affect my choices in another, so I thought it best to look at it holistically.
- SWCG
- VS pump
- LED light control
Topic 2: Pump
Topic 3: Filter
