Hey everyone, I am brand new to the forum, my pool info is in my sig, I am really new to pool chemistry I used to clean my friends pool almost every day but his dad did all the chemicals, here's my trouble I keep getting algae growth on the sides and floor of my pool, no full bloom, but it has to constantly be scrubbed off. I learned for myself not to bring my water to the pool store, they did a great job with the brand new liner last summer and did the opening chemicals, suggested I float tabs and I bought everything from them and did exactly what he said and for a week no chlorine on the tests, even their test came up zero so not going there. Up until finding this site I have been using test strips, when my overtime hits this week I will order a good kit per your suggestions. I have stopped using the pucks since finding the site, and have been adding liquid shock which lists 12.5% sodium hypochlorite, the strips show 10PPM FC and my test kit only goes up to 5, not sure if it's an accurate thing to do but I did 50/50 pool water/filtered water and tested and got 5PPM, so I assume I have at least 10PPM. The algae seems to come back every 3 days or so and my pool always smells like chlorine. After testing with a cheap kit I believe my CYA is high 70-80, I still want the better kit and need to get used to the test, so by the CYA/FC chart I should be at the 10PPM level. I have been adding algaecide once or twice a week, adding a full gallon after scrubbing the algae, after reading someone elses post I was wondering if my algaecide is part of the problem? It is cheap stuff, lists the active ingredient as n-Alkyl(60%C14 30%C16 5%C12 5%C18) dimethyl benzyl ammonium chloride 4.98%, n-Dialkyl(60%C14 30%C16 5%C12 5%C18) methyl benzyl ammonium chlorides. We have had really poor pool weather in the past couple of weeks, cloudy, rain, fluctuating temps, but it has finally become pool weather and I want to stop the algae from coming back, I know better test results would be more helpful, right now my main concern is the algaecide, is it bad stuff? and what should I use? For what the test kit is worth with the FC at 10 or more I have pH 7.2, TA 70, CH 250, and CYA best I can tell is 70-80. I forgot to check the water temp but it has been holding pretty well at 78-80*F. Sorry for the lengthy first post but I have already learned I have been using the wrong stuff from listening to pool store clerks, and want to start remedying the situation, even with my troubles this year has been far better than last year. Thank you for your time and hope you all are enjoying your pools.
