Hi,
I'm using the Taylor test kit. I don't have any issue with measuring the various chemicals... except the calcium hardness. When adding the reagent, I don't have a clear cut between red and blue. The water slooooowly transitions from red, to purple, to light blue, to blue. So my calcium hardness is somewhere between 400ppm and 650ppm.
I read it could be caused by copper. I believe I have some (I'm not sure where it comes from, I only use liquid chlorine and muriatic acid. Probably a left over from the previous owner? Anyway..). I also read that adding some drops of the re-agent first would help. It didn't for me.
Here is what I did:
When I get the water tested at Leslie's, they tell me my calcium hardness is 350ppm (I know the TFP community doesn't recommend pool store testing, but for other chemicals their measures are consistant with what I get, so I think they do it right).
Here is what I did:
- used 10ml water sample, then added:
- 8 drops of the reagent (R-0012)
- 10 drops of R-0010
- 5 drops of R-0011
- then added R-0012 drops again.
