Currently my pump & filter are about 12ft from my pool. I'm using several pieces of flex hose to make the connections to the skimmer and return. I'm adding a heater this year and I want to switch to everything to hard plumbing. Is 1 1/2 pvc sufficient size all the way around?
The heater is currently set up with 2' adapters. Any reason I should not change these to 1 1/2' to keep all the plumbing the same size or should I go 2' all the way around? Other than a higher flow rate any other advantages.
I take my pump/filter inside in the winter months and will make whatever set up I go with able to be disasembled so I can take all of it inside as well.
Thanks for any Help
John
Thanks for any Help
John
