Hi,
Hoping to hard plumb this AGP, due to flex hose/clamp drips we could not get rid of last year, but time is running short for me to open the pool.
We want to add a shutoff valve between the skimmer and pump and possibly a cheaper inline puck chlorinator for some weekends away.
I don't like using the vacuum hose attachment to the skimmer and thought about a vacuum attachment in-line but not sure how to filter debris.
I also don't know what size plumbing I should use. Our filter has larger size screw fittings that are not used except for incoming water from the pump, but other than that it is all the smaller pipe.
We'll probably need 2 unions for disconnecting the PVC fountain assembly we made last year and saw these recommended in another thread.
Hoping to get most of the supplies at Menards and I know to get pressure PVC. This will be my second time ever doing PVC. Any other hints or suggestions? Edit: I see now we'll need 7 unions to take it down for storage in the fall.
