Hi All,
How concerned should I be about hairline cracks in a new grouted pool bottom, or is it typical? There are 3 hairline cracks, one down the centre of the slope between the shallow and deep end, and 2 opposite each other in the deep end on the sloped walls down from the steel walls. At the two locations in the deep end, if you hit the grout with your fist it feels a bit hollow underneath, so I'm wondering if some material settled underneath and the grout is thin there.
What should I be asking the PB? I assume this is something that could cause an issue after the liner is in and the PB is long gone?
Thanks for the advice!
