Long story, but I decided to use the same landscape company that installed my pool 7 years ago to install a pool heater. I wanted to pay online prices, but no warranty. So the Raypak 206 was about $300 more from the dealer. Of course, they don't run the gas or electric, so I'm not sure what difference it makes that they sold it to me???? Anyway...
Looking at the pictures, here are some concerns/questions I have:
1 - the in/out lines on the heater are 2", whereas the line from my skimmer into the filter is smaller. I'm still filling the pool, so I haven't turned on the filter yet.
Will that create any pressure/circulation/efficiency issues?
2 - As you can see, he used flex pipe. We talked about moving the filter to be in direct line with the heater, but I think he was losing patience and just decided to run the lines where is. On one hand, I'm glad, because the filter is better for me where it is, plus we would had to have cut and installed a new power outlet for the filter. However, you can see the flex pipe at the filter is "wedged" against the case of the filter. These are thick flex pipes obviously, but I'm not sure how this will hold up long term.
3 - After these pictures, I added some wood to support the return and feed lines. Someone (me) is bound to step on those, so I want it to be more solid. I'll probably just build a small bridge, especially over the return pipe and install a more sturdy support. It's in my main thoroughfare to the skimmer, filter, hose, garden hose, etc. Having the line buried would been the cleanest, but I'm not sure I would have wanted to pay for that. I thought for a while on this and there just wasn't a better spot for the heater.
Anything else you can think of I might want to do, before turning on the filter?
The plumber will install the gas line, run the electric, etc. So hopefully this will be up and running next week.
