Hello everyone!
My name is Chris, living in the greater D.C. area. I first want to thank this forum for the valuable information. I've lurked a bit trying to solve my algae problem; this forum and the pool school has been invaluable.
I have an approximately 40,000 gallon standard pool. Sand filter with inground spa.
I developed the dreaded SWAMP maybe 2 weeks ago (became an oddly pretty neon green color). Found here and maybe the last 5 days started the SLAM process by doing the following:
1) absent a more sophisticated chemistry test kit I had to start simply by dumping cumulatively 8lbs or so of cal-hypo (I knew early on that I had almost no calcium so was good to use that for the time being).
2) twice daily brushing of the pool sides
3) twice daily backwash/rinse
4) running the Polaris to agitate algae into the water column.
My Taylor 2006c kit came today and I'm finding th following results
TC: 28 ppm (FC=27ppm, CC=1ppm)
pH= 7.4 (meaningless at this level of chlorine, no?)
CYA= 50-60 (not really sure what constitutes the black dot disappearing)
TA=90ppm
Harness= 200ppm (need to ease off cal hypo at this point)
Where I'm hoping for help:
1) where do I go from here? It's been at 28ppn+ for three days and am not seeing any color change: light green and hopelessly cloudy. If it weren't for the cloudiness I would be able to see the deep end of the pool. Cloudiness has actually gotten worse the last couple days.
2) I smell chlorine! I generally understand smelling chlorine is not good, but I'm not sure if it's natural to smell it during the SLAM process. But it smells like a public pool = chloramines? The 1ppm combined chlorine, based only my research, is not a good thing.
Thank you in advance for my help you can provide.??
TA=90ppm
