We're in the process of a drain and fill to reduce CYA. Since the water is down we're checking the pool for any other maintenance. Two issue for ya'all, one about tile and one about plaster...
1) There is tile at the water line and also run horizontally below each step and the bench. There are some small holes in tile grout. Is this in need of repair?
2) There are some small cracks in the plaster on the horizontal part of the steps. Is this cosmetic or is this in need of repair? We are doing some plaster repair in other areas using E-Z Patch Fast Set. The brown spots are not stains, either water still drying or just some discoloration from leaves falling in that hadn't been cleaned.
This is my first time posting pics - hope I did it right. I have some more pics if needed.
Appreciate any input.
