Hi All. I found this site over the weekend when trying to address a green water problem I've been fighting for at least 6 weeks. After reading this site, and taking my water in for testing, I have concluded that my primary issue is related to having a high CYA value of 90. I have been getting green water with very little algae on the pool walls. I would shock the pool with Cal Hypo bringing the FC up to 14. It would remove the green over 2-3 days, but the water would be slightly cloudy. I figured this was filtration, so I let FC drift back down to 4'ish. The pool would then quickly turn green again. Duh, I now know I need to maintain a FC of 10-12! I debated draining 1/2 my pool, but I have well water and would have to get water trucked in...big $, and not really an option. I'll address CYA when I lower my pool water at winterization and stop using chlorine pucks. That's the background, here's my question....
How quickly will the FC drop when my pool is green and I SLAM it to 30 FC with a CYA value of 90?
I dumped a truckload of 6% bleach in the pool last night and brought the FC up to 28-30. I check this morning and it's at 24+. I don't have a DPD-FAS testing kit yet...it's on the way...but I used my DPD testing kit by diluting the water with 3 parts distilled water to 1 part pool water. Maybe not exact....but tells me I'm at 24+. The water looks better, but still plenty of green and cloudiness, with lot's of dead stuff on the bottom of the pool.
I get that the CYA will hold the chlorine longer in the sun, but I didn't think it would stop the algae from consuming it. I also understand it will take longer for the chlorine to do its job, but is this what I should expect? Is there anything I should be doing differently? I'm worried that if I bring the FC back up to 30+ again it will be 2 weeks before I can swim again. I really expected the FC to drop dramatically last night.
Thanks for any help. I'm excited to be a part of this community and I look forward to a trouble free pool!
Jeff
Jeff
