+1 on this.Every time you go below target you are letting the algae grow again.
The trick, LaurieBlue, is to dose frequently enough to not drop below slam. But if you can't do that and it takes a few extra ppm to hold, provided you're not ever going nearly as high or higher than the mustard slam value shown in PoolMath for your specific parameters, then its my opinion that you'd make faster progress without undue harm to equipment.
At the same time, it IS true that exceeding the recommended SLAM value by more than a few points does waste more chlorine because higher-then-needed FC burns off without "doing anything."
So in the early days of slam where FC drops the fastest, you kind of ave to choose between optimal progress in terms of either frequency r to dose in a way that helps compensate.
If you spend 6 of 8 hours below slam value, then you only slammed for two hours. So try to track how fast your FC is being used to get dialed in a bit better.
