Green Algae w/Acceptable Chlorine Levels??
garroyo130
84
Austin, TX
Hello all, seeking advice on what could be causing this. Just went out to add chlorine and noticed that there was what appeared to be green algae. I brushed that area of the pool clean and immediately tested chlorine using DPD and got a 5ppm as is expected.
I bumped CYA to 50, 2 months ago and after testing chlorine consistently and getting usage of 3ppm/day, I began to blind add 3ppm Chlorine per day to keep levels between 8 and 5. The pump is running 24/7 and there is very little organic matter (leaves, sticks, etc.) in the pool.
Anyhow, should I be worried about what appeared to be algae? Is it possible to have algae but remain within the acceptable range of Chlorine throughout the day? Any assistance is appreciated.
