We just moved near Phoenix, AZ and I've heard the water is very hard here and it's not good to use non-softened water for the auto-fill system so I decided to use my RV water softener to add about 1.5" of water to the pool (auto fill wasn't working - different story). Prior to doing this I decided to test the water hardness of the water that is going into the auto fill system with some "Total Hardness" test strips that I used in the RV. The water tested at 40ppm which is near the bottom of the scale on the bottle. WhooHoo! I don't need to use the RV water softener! Or so I thought....
I then used the same strips to test the pool water. Yikes!!!!! It was pegged out on the hardness scale - like 1,000. I didn't expect that because when I last tested hardness with my Taylor 2006C kit in December it was around 380. I then tossed the test strips and tested the pool (390) and also tested water from multiple locations around the house using the Taylor kit. Here is what I found:
Calcium Hardness results-
Outside faucets (3): 90ppm
Kitchen sink: 90
Bathroom shower: 0
Bathroom sink: 0
Faucet at water softener: 0
Outlet from RV water softener: 0
What surprised me was how low the calcium hardness was at the outside faucets (one of which feeds the pool auto fill). Since everybody said the water here in my area was hard I was expecting something more like 500ppm. In fact, after measuring 90ppm at the outside faucets, I thought at first the entire house was plumbed through the water softener. That was until I tested the bath shower and sink and they came back at 0ppm. I've never had a water softener so I was surprised the kitchen wasn't plumbed into the softener.
Anyway, I'm going to continue using the RV water softener to fill the pool. I'll only use the auto fill when we're gone for an extended period of time. I'm also going to wash the car using the faucet at the water softener.
There apparently is a huge difference between the results from "Total hardness" test strips and the Taylor CH test.
Kitchen sink: 90
Bathroom shower: 0
Bathroom sink: 0
