Folks,
Hope all is well.
I'm getting ready to place the paver bricks on my supports and compacted ground, but I have a few questions before I proceed.
For a 24' pool I'm getting 3 yards of screened sand which should be plenty given I'm using a foam cove. But I'm also using a Gorilla pad below the liner. That being said, if I'm shooting for 2" of sand, I assume this means that I'll have about 1.5" of sand above the bottom track? i.e. the support base is flush with the ground and the bottom track is about 1/2" in height. Therefore 2" of sand will be about 1.5" above the track. How do you best keep the track free of sand when installing the wall? Just keep the sand piled back a bit from the edge until wall is install?
Now for the Gorilla pad and cove. I assume that I place the Gorilla pad down and then the cove is placed on top of the Gorilla pad at the edge. Do you recommend duct taping the seam between the Gorilla pad and the cove?
I'm also installing a wall foam as I'm hoping this will help retain heat and additional liner protection. Do I overlap that with the top of the cove? Or do I place that tight up to the seam on the cove and duct tape it?
Thanks in advance.
-J
Hope all is well.
Thanks in advance.
-J
