good water chemistry but ton of algae
ethan1244
In The Industry
May 1, 2024
17
Cusseta, AL
I service this 14k gallon above ground pool once a week and when i stop by i do either 2 pucks or 1 gallon of LQ TO have a FC of 3-4ppm but for some reason this past week it went from perfect to almost swamp green and having running a spin disk test i noticed the phosphates are through the roof! i love using the API! revive as a good flocculant works amazing but i swear even those its advertised to remove phosphates i feel like their lying before my phosphates were 1342 and the day after i used it there at 4700 now
P.H.- 7.5
TA.-70
CYA-20
FC-1
Phosphates-4,000ppb
The water chemistry isn’t perfect. CYA of 20ppm won’t adequately protect the chlorine from sunlight degradation with weekly visits.
That will need to be raised considerably once it's hot out. Your liquid dose above is 8.9 FC and pucks are 7.8 FC, and you may lose 4 FC per day soon. You can't just spike it to 30 for the week because it burns off as a %, much faster when the # climbs high.
You guys are getting warm out already and the additions likely weren't cutting it, on top of the low CYA as mentioned above.
