- Jun 22, 2017
- 861
- Vinyl
- CircuPool RJ-45
I've got a Coleman 18'x48" AG pool with an estimated 6700 gallons in it. Currently using the cheap filter pump combo that came with it and I'm trying to find a good pump and sand cartridge filter (combo or separate, either is fine) to replace it. I plan to replace the soft hoses that came with it with PVC pipes and will mount the pump and filter 30ft away from pool on the concrete base the well is mounted on. Also adding a Hayward skimmer to the pool and gonna make a DIY fountain with PVC pipe that extends out of the returns pipe.
Side question, are the more expensive Jandy Valves worth it, or will normal PVC valves be fine?
