- May 1, 2019
- 47
- Plaster
- CircuPool RJ-45
This is my first season using the TFP approach and liquid chlorine (last year I used tabs - I have since replaced most of the water).
I'm very happy with the water - its is sparkling and clear, and I no longer see the hints of algae that I used to get occasionally.
However, I seem to be going through a _lot_ of chlorine. This approach seems like it will be a lot more expensive than an $80 bucket of tabs that lasted me the whole season last year.
When I originally measure CYA, I thought it was at 50, so I've been following the recommendations accordingly (trying to keep between 6-8). But with all of the FC loss every day, I started to suspect my CYA was lower and I'm burning off a lot, so I retested yesterday, and it seems like it is closer to 40, so I've changed my target to 5-7.
I've attached my recent logs - you can see I've been adding more than half a gallon every day.
Is this "normal"?
Should I consider adding a couple tabs to try raising my CYA?
Is this "normal"?
