Hi all, newbie pool owner here.
Pool is an above ground vinyl with about 6500 gallons.
After a vacation and the kids not touching the pool we had a major algae outbreak that has taken me all month to actually start getting a change in color.
Chemistry at start of SLAM:
FC 0
Ph 7.2
TA 120
CYA 30
So after a month of trying to get this outbreak under control I'm finally seeing some changes in color and the pool is now a light turquoise from dark green.
As I haven't passed the 3 tests to stop the SLAM I'm still maintaining my FC at SLAM levels but just today I tested my CYA levels and it has dropped below 30. Is this something I should fix before continuing the SLAM? Kind of worried to loose the progress we have made so far after trying for so long.
Also now that it's changed color to a lighter should I be using any clarifyer to help the particles settle or should the pool clear up on its own?
Test kit I own is a Taylor's K2006
Thank you for the help
FC 0
Ph 7.2
TA 120
CYA 30
