so i just got the Poolmaster 5 way test kit and had a few questions on my results....
1. did test 1, the chlorine test. my color was around 1.0ppm, which means i need to add chlorine to get into the range of 2-3ppm. how much liquid chlorine do i need to add?
2. i did the bromine test and my color matched the 1.3ppm level. the instructions say 4.4ppm is normal. do i need to add bromine? how much?
3. ph test - ph came in around 7.8 or so. so i did the acid test and i needed around 2 drops to get the acid color more in range. according the to the chart for a 10k gallon pool, add 2 pints of acid, which i did.
4. total alkalinity - i dont get this test at all. it has me add solution 4, 5, then add 3 until color changes. changes to what? mine started out blue, and i added around 15 drops with no color change and quit. what color is is supposed to change to? then it says to multiply the number of drops by 10. lets say mine is 20. then 20X10 = 200. what does that tell me?
