Generic Jandy Cell
Apr 20, 2012
18
Tampa, FL
Hello all. I have had a pretty bad experience with the Jandy Aquapure 1400. I am only getting a couple years and they fail. Looking at other options and wondering if anyone has tried some of the generics that are on the market. Here are two I found:
- Salt Cell Supply: Generic Jandy
- Salt Pool Store: Generic Jandy 2
I have a whole Jandy automation setup so these being plug and play is nice.
A couple years and then failure is typically indicative of improper water chemical balance. Specifically, your CSI is most likely in the positive end. Do you have a proper test kit like the TF-100 with Taylor reagents? If so, please post a full set of pool testing parameters. It would be helpful to know your calculated CSI.
