Gday all,
Michael from Sydney. Its always funny you only find out about great forums like this until you know what hits the fan .
Being pool schooled at the moment. One thing I noticed is that data is relevant to fibreglass, vinyl or plaster. Whats the closest match to a fully tiled pool?
I have the same problem and many australians it seems when it comes to pool test kits, both the NQ and the Clear choice labs are out of stock and have requested when they will be getting some in, until then I am struck with the pool shop. The K2006C is just too expensive.
Had a mustard algae problem and although the water is clear I think it is still there. The pool shop only measures chlorine to 10 so cant know if I am SLAMing the pool properly and am just guestimating at the moment.
But the forums are right, I was duped into using a tropiclear algecide and since then (2 weeks ago) the amount of chemical recommendations and purchases I have made to rebalance the pool has brought me here.
My current readings are:
Total Chlorine 10 (max measure by pool shop)
Free Chlorine 10 (max measure by pool shop)
pH 7.5
TA 70
Hardness 175
Stabiliser (CYA) 50
I was told my CYA was fine. From readin here I understood 70-80 is the target I told them I had a SGW and still no budge from them?
Whilst I dont have testing gear are there any recommendations of waht to do apart from what I think which is:
Raise my CYA to 70-80 and follow the SLAMing proceedure?
CHeers and thanks for a great place to vent my frustrations
pH 7.5
TA 70
Hardness 175
Stabiliser (CYA) 50
