[h=2]Our gas company is going to be installing a 2PSI meter at the house. We will need a regulator on the house line to keep the pressure down. We will have a Pentair 400K BTU natural gas heater to heat the pool and spa. The run is about 130ft. We have dug an 18in trench from the meter to the pool equipment pad and installed 2.5in PVC pipe for the run. I assume we will need medium density polyethylene flexible gas pipe to run from the meter to the heater. 1-1/2 MDPE seems to be sold in 500ft rolls. However, I saw 1-1/4 MDPE in 150ft rolls (1-1/4" IPS SDR11 PE2708 Yellow MDPE Gas Pipe 150' Coil - Hdpe Supply) for $180. Anyway, what size/type of pipe do I need for this run? What type of regulators will I need?[/h]
