Gap Between Tile and Coping?
sjfrank
13
Connecticut
New to owning pools, bought house that had one that was severly neglected for years. There is a gap running between the pool tiles and the cement coping. It runs about 1/2 the length of the pool and 1/2 inch at its thickest. Not sure if this is something I can fix with the pool open and full?
2 sections lifted at some point in the past and I will need to bring in someone to fix that, but was hoping to patch this problem now if possible. PXL_20230802_190737439.jpg
2 sections lifted at some point in the past and I will need to bring in someone to fix that, but was hoping to patch this problem now if possible. View attachment 519188
Get a level and confirm that the deck has sunk at the back (opposite the pool tile). This is assuming this is a cantilever style deck. You can lift the back of the deck back up and that gap may close up. My pool had a similar issue but way worse.
If that is just coping, it looks delaminated and needs to be rebonded to the pool structure.
Reactions: sjfrank and kimkats
Thanks, it is hard form me to tell if its sunk in the back, deck is on a slope down from this photo. B
