I went to check my skimmer basket this morning and there was a frog in the mouth of the skimmer. When I pulled the basket out to remove some leaves, the frog must have went down one of the holes in the skimmer because I didn't see it anywhere inside or outside of the pool. I've kept the pump off and the basket out all morning to see if the frog will come out of the hole and I don't see it anywhere. I checked the pump basket and it isn't in there. I am concerned about turning on the pump because I'm worried that the frog could clog the skimmer line. Could someone give me some advice on what I should do about this frog? Could my skimmer line get clogged if I turn the pump on or is this unlikely to happen?
