Hi,
We are having a new 18x36 IGP installed and it comes with the Frog mineral system. I raised concerns about the Frog with the pool guy and he told me...
"You'll love it. It uses less chlorine, makes the water feel softer, etc, etc. It comes with the pool and if you don't want to use it, you can just remove the chlorine canister and mineral pack and set the lever to zero."
So I'm tempted to try it for the first season and see how it goes. Of course I want to keep an eye on my chemistry so I'm buying a TF-100 kit.
What ranges should I shoot for while using the Frog system?
- pH
- CC
- CH
- TA
- CYA
I fully expect that I will not want to buy a new mineral cartridge next season. Can I still use the Frog unit as an in line chlorinator?
Here is my thinking - First, remove the chlorine pack and mineral pack. Second, put regular chlorine tabs/pucks into the Frog housing and set the lever on 5.
Then test the chlorine level over several days to fine tune the lever setting on the Frog unit. Find a good equilibrium and keep it set there.
Then I would continue to do daily Chlorine and pH testing and weekly full (TF-100) testing and use the BBB method ongoing.
My logic is this: Rather than having to add liquid chlorine / bleach every 2-3 days, my re-purposed Frog unit would keep a trickle of chlorine running into the pool while the filter is running. Things might get a little out of whack if the kids have a pool party or something, so a bit of bleach might be needed occasionally on top of the Frog trickle.
What do you think?
Doug
- pH
- CC
- CH
- TA
- CYA
What do you think?
Doug
