Here are her numbers:
FC 2.5
CC 0
PH 7.5
TA 80
CH 250
CYA 90
temp ~70
the pool water is clear, but there appears to be pollen accumulated in the floor there are pollinating trees/ plants all around the pool.
She has a pool service. I tried to convert her but she has 5 kids and her husband is gone for work most of the year. I don’t think at this point she is willing to go full TFP!
I instructed her to run her pump and sweep 24/ 7 to get the pollen cleaned up also indicating a filter cleaning would be necessary. Also giving her some hair nets for the skimmer baskets to help out.
A bit bit more info:
cartrige filter
single speed pump+ booster for sweep.
~28,000 gallon plaster IG
First photo is before I clicked on the sweep and pump showing accumulated pollen? Second photo is after sweep had run for a few minutes.
Anything else I can do for her? I will likely end up cleaning her cartridges as well.
I know a partial drain is imminent with her CYA, but so don’t want to push too hard!
Thanks gang!
mark
FC 2.5
CC 0
PH 7.5
TA 80
CH 250
CYA 90
temp ~70
cartrige filter
Thanks gang!
mark
