Freeze Protection
JackF
2
Austin, TX
I have Hayward E-command system software, HPC-4-ACT-RC and the clock timer has malfunctioned and the current time is incorrect. So I decided to run the pump constantly divided between slow and high speed.
However, the freeze protection is now not working correctly. When the pump cycles to the spa the valves move such that the water in the spa is drawn out till the spa is dry and the pump loses prime. Does anyone have the settings for the freeze protect, so I can correct my issue?
Welcome to TFP.
Observe if your suction actuator is moving correctly between POOL mode and SPA mode.
Post pictures of your actuators in POOL mode and SPA mode.
