- May 11, 2022
- 8
- Fiberglass
- Hayward Turbo Cell (T-CELL-5)
This is our 2nd season with our pool. I use TFP test kits and have replaced the reagents I was low on or read expired this season. Everything is kept inside the house.
We are getting to the end of our season (we have a heater so that extends it a bit) and we’re planning a swim this weekend before closing it up.
I have to be honest and say, I’ve neglected the testing over the last 3 wks. We have an automatic cover and we’ve been traveling a lot and I just didn’t get around to it. I also made a doozy of a mistake and forgot to turn the chlorinator down/off while it was covered, little sun, and we weren’t using it.
I opened it up 3 days ago to get things in order before this weekend and could smell the chlorine right away. Immediately turned chlorinator off, filter speed up, brushed walls, and grabbed some water to test. FC was 35. Drained some water off, refilled with hose, tested again, 30. Rinse/Repeat 2 more times over 2 days. Last night I drained more than I normal would and refilled. FC is still testing at 22.5! I’m so frustrated I could scream! Is there nothing I can do to get the chlorine down?
My other numbers are as follows:
FC: 22.5
CC: .5
PH: 7.5
TA: 80
CH: 350
CYA: 50
Pool temp is 74
FC: 22.5
CC: .5
PH: 7.5
TA: 80
CH: 350
CYA: 50
Pool temp is 74
