Hello, This is my fifth year following TFP protocol, which has always been successful! This is my first year with a "swamp-to-oasis" situation, though, as my in-ground vinyl pool sat for 8-weeks after opening with no chlorine or circulation. I did a pump replacement and other equipment/electrical upgrading, which took an agonizing 8 weeks.
I have been meticulously following the Swamp-to Sparkling-Oasis directions, yet the pool will just not fully clear! It looked milky with the initial dead algae and now looks hazy. Still can't see the bottom all, and today is my 15th day of SLAMMING. I see VERY small improvements day-by-day, and I understand with my old Hayward S-200 sand filter, things can be slow, but this seems ridiculously slow. I have been adding a generous 1/8 of a cup of DE to speed things along from one to three times a day. (Depends on how closely I can monitor the filter pressure.) I am backwashing when filter pressure rises 25%. When I backwash now, the water does not even look that cloudy. (It maybe looks cloudy in the viewing glass for 20 seconds?)
I am now getting worried that I have had the chlorine up too high for too long and my vinyl liner might be affected. Also, we can't swim...and it's nearly July : (
Here are my current readings, as of this morning, which have changed a bit from the beginning of the SLAM.
• FC 13.0 (OCLT -- no loss for about the last 5 nights)
• CC 0 (None since day 2 of SLAM)
• PH 7.2 (Was sky high pre-SLAM, added Muriatic acid then. Added 50 oz. by measure of Borax last night, as my pH had dropped to 6.8??)
• TA 60
• CH 50
• CYA less than 20 (Was 30 for most of the SLAM, but has been dropping due to backwashing and water replacement. I will add more today to get it back up to 30.)
• CSI -1.31 (according to Pool Math)
A few other factors that I can mention, and I am not sure if they would affect anything:
-- One of my return jets is not working at all. It is the jet furthest from the pump. I only have two return jets and one skimmer.
-- Tried to get the second jet to work by putting a smaller eyeball on the jet. This shot my pressure up to 22.
-- The skimmer has no door. (Fell off when we moved in and we never replaced it.)
-- I always use a pool sock in my basket as it catches the bugs and pollen so well. The sock was really coated in dead algae initially, but that has really dissipated. Does not SEEM like it is catching dead algae at all now. I clean it every day, and rotate with other socks.
-- Before I add dissolved DE into the skimmer basket slowly, the filter pressure is between 15 and 16.
-- Pool has gotten a vacuum and/or brushing every day. I even pulled out some of the coping and brushed behind it and scrubbed the algae off the coping itself, while it was pulled out.
I think I have told you every detail of this saga! I'm stumped as to what I should do next and all suggestions are appreciated.
~Julie
• TA 60
• CH 50
~Julie
