- Jun 14, 2018
- 208
- Vinyl
- Hayward Aqua Rite Pro (T-15)
That, my friend, is an entirely subjective question. You will get answers all over the board. If 10 or 20 bucks aren't worth the hassle, no. If you want to get some of your money back, yes.Are they worth enough to bother selling?
Thanks.That, my friend, is an entirely subjective question. You will get answers all over the board. If 10 or 20 bucks aren't worth the hassle, no. If you want to get some of your money back, yes.
Can you return the unused items to the pool store?
100% calcium chloride. It is good to increase CH. You have a vinyl pool, so it is really not necessary. I run CH in my vinyl pool at 200-225. One for health of my heater, other is that liners, apparently more recently are being made with some calcium content. Best general recommendation is to run your vinyl pool at 200 or so.As it is Clorox, check the back label and the SDS for additives. If no additives then it is OK, but may or may not be necessary.
Sand.What kind of filter do you have?
Keep it. I can be useful to improve filtration in the future.Sand.
Added this to the skimmer basket in small portions to help clear the water. I think the problem was originally caused by the flocculant. So as I’m not using that I wonder if I should get rid of the stuff.
It’s not flocculant though. It’s DE. You can use it if you want to. Up to you. It can make the water more clear.Sand.
Thanks for that link.It’s not flocculant though. It’s DE. You can use it if you want to. Up to you. It can make the water more clear.
Add DE to a Sand Filter
A clean pool filter will increase the efficiency of your pool! ... your filter are to backwash it, clean the manifolds and grids, and add new DE.www.troublefreepool.com
