Last year I had ball valves and needed to disconnect the union connections at the heater and move the heater a bit to blow out the lines in the heater. This year I installed two 3-way Jandy's at my heater bypass to blow lines out in the winter so I wouldn't have to disconnect and move the heater. A while back some of the guys here on TFP told me these valves are really not meant for this as they are not water tight. Pool guy at one the well known pool places in NJ told me they are air and water tight and any water that came out after removing the caps was just sitting in the short stub piece. I showed him this video and he said that is not normal and of course he has been installing these valves for years and they are 100% water tight. I replaced the O-rings and paddle with a new one and it is def not water tight. The video shows the water coming out continously as the valve is in the closed position. Next year I will replace with ball valves and add a T with cap to blow out the lines. Not sure if it's because I have a 2.7hp pump or not? Could not upload video but here is a frame pic
