Foggy window in Jandy TruClear Pro salt generator
deverelle
0
5
PFLUGERVILLE, TX
Luckily, it's under warranty, but it's not integrated with my iAqualink 2.0 system so I rely on this little window to tell me my salt level (aside from water testing) and today when I did my weekly check, the window is filled with moisture. IMG_9708.jpg Does anyone have this system or have seen this problem?
I'm really having the week because I just rebuilt my Polaris 480PRO and it's still not picking stuff up! Oye!!
Is the Jandy pump controller window susceptible to the same potential moisture and fog build up? I have one that is out in the open with no cover. Is there a way to prevent the potential fog or moisture in the window of the controller? I'm not sure if a shield over the unit where water can just run off the shield and not necessarily run on the unit.
Why isn't it integrated? Should be a simple matter of running the 4 wire control between the two. If you are out of empty connectors you can double them up.
