Hello Jason, Dave et al.,
here is the latest. My TF-100 pool test kit has arrived on April 4th. But first things first. Before that, on Tuesday April 1st, I hired a pool repairman to fix a white plaster patch on the pool wall where it was wearing out . In order to do so we had to drop the water level about 1 inch below that point. About 1/3 of the pool water it turned out. So, while the patch was drying out, I asked the guy if he had a Taylor test kit in his truck to measure the CYA . He did . And the CYA was 80 in the adjacent Spa as the water level was still high there. So, the next day I re-filled the pool with county water . The foaming has almost but stopped . Only some intense air bibbling from the spa jets as it used to . The PH was off - too low. The FC was 4. I adjusted PH and shocked the pool. Was running for 2 days.
Fast forward to Friday the 4th. The kit came. CYA was 40 on Saturday and today. The FC was 7 . CC was 0 . So, will shock it again tonight to bring the FC to FC shock level of 16 and keep it for a week or so, will see what will happen to the almost gone foaming , then let it drop to FC =3 and keep it at 3-4 ppm.
I turned of off the inline chlorinator for now so it will not put any extra stabilizer in the water.
The PH is 7.6. and TA = 110.
So far, so good.
Thank you all for your help and advice.
P.S. I think I know why the CYA test in the pool store was measured so low. Your test kit says to wait at least 30 seconds before shaking it agaian and then pour in the tube to watch the black dot to disapear but they invariably just measure it right away with no waiting for 30 sec. So, that could be it.
Another thing : I compared results from the test kit to the strips : the CYA on the strip shows shade right below 50 as well . So pretty close.
