New 1 month old hot tub. Filled and purged with Awwsome. Filled with oklahoma city water. 10% pool bleach from Walmart added daily per pool math.
K2006 results:
FC - 8
CC - .5
pH - 7.8
TA - 60
CYA - 30
CH - 100
I also am running gentle spa in it. Although I haven't added any since the initial fill, so it's probably diluted as I i've had to add some water to it from time to time to keep a topped off and adjust cya accordingly. I haven't added more gentle spa as i'm not sure how much to add, i'm not sure it even makes a difference.
Why is this foam happening? With no air jets the water is crystal clear as depicted in last photo. Hit the air jets and you are in a bubble bath. I tried scooping it out with a net... theres no end to it. I rinse filter every 2 weeks, it's never really dirty. At the same time I wash the "sun" floating in the tub that gathers contaminates.
My daughters wear swimsuits. The wife usually wears her bottoms and a uv top shirt because it's cold out. When the kids aren't home, we usually don't wear anything in tub.
I've been making the kids shower before they get in. We don't use excessive body oils or lotion in this house.
It's not a scummy foam. It's almost like it's soap.
How can I get rid of it?
Thanks!
K2006 results:
FC - 8
CC - .5
pH - 7.8
TA - 60
CYA - 30
CH - 100
Thanks!
