So this isn't exactly "under construction" but I think this is the best forum.
Here's the situation: We live in Pittsburgh, PA and have a relatively new in-ground gunnite pool that is partially indoor and partially outdoor. The pool extends into a heated/conditioned poolhouse. There is a Cover Pools cover and there is a glass garage door that covers the gap between the pool house and the outside, sealing (hopefully sealing) against the pool cover.
On the inside portion we have a perpendicular (sideways) facing endless pools fastlane and would like to be able to use that in the winter.
The plan is to continue to heat the pool (covered outside, open inside) during the winter in order to be able to use it in november - march or so.
My question: in order to avoid going broke and hastening climate change we would like to not only cover the pool but insulate underneath the pool cover and thereby minimize the heat loss from the outdoor portion of the pool. What floating, insulating material should we use for that? (I have some ideas, but I'm actually interested in casting a wider net to see if I'm thinking about this correctly).
Additionally: are there other things we should know about this wacky, unreasonable project?
Thanks!
t
Thanks!
t
