I have a cracked 2" 45 degree fitting that needs to be replaced. The problem is the pipe is in cement. I broke away enough cement to expose the fitting and cut it out. The problem I have is if I put a new 45 on the pipe will be shorter and not line up properly. I figured I would ask the pros for a tip or trick. I am thinking someone has to make a pipe extender that I should be able to glue to the outside of the 2" pipe that would narrow down to a 2" pipe I could put the 45 on.
The pipe is cement in so I wont have much flex in lining up the joints. There is also a pipe behind the broken 45 that concerns me about digging any further with out damaging it.
Broken fitting is on the bottom pipe which is the suction line.
Bottom picture is upside down.
