- Jul 4, 2022
- 10
- Plaster
- Jandy Aquapure 1400
Problem: Have a copper frog that’s copper tubing, from mouth to belly, has a small leak between its neck and mouth. I fixed one small leak where the copper tubing was attached to the inside body for support had broken loose. I used JB Weld Water Weld. The remaining leak is very hard to access because the neck to mouth area is very narrow and curves downward making it hard to ensure I get the Water Weld in the proper spot. You can see in the pic where I applied the JB weld and that the tube curved downward so much you can’t see it. I have a plastic coated wire through the inside of the tube to ensure I don’t accidentally seal the copper pipe completely. It’s a small crack but can’t see it.
Question: Anyone have a recommendation on how to seal the crack that I can’t see and is near impossible to get two of my fingers on. I’m fine with pouring something to seal the entire inside of the head/neck area.
