BTW, most people put the sock into the skimmer basket....put a rubber band on the open end...Just make sure the sock does not get into the pipes....fast-flowing water coming into the skimmer basket and through the sock will dissolve the CYA faster than what it sounds like you are doing...hanging it over the edge of the pool into the waterline. I still swear by my 5-gallon bucket CYA adder method, posted earlier in this thread. Add mostly dissolved milky CYA slog at dusk, sweep the small amount that falls on the pool floor into the drain, let the filter run an hour, ....and the TF-100 test kit measures it at the proper level calculated by Pool Math at daybreak.
I have mine hanging in front of the return jet, my son has been squeezing it and says its getting smaller and smaller.
