First timer
Arc-E
2
Western PA
Hi - Just had 1st hot tub delivered and shortly after came across this site - very interested in the approach advocated here and have learned some so far - though much more to learn. Regarding how to get started - I did receive a starter kit that I used out of the gate though haven't been successful balancing water yet. I used a bottle of metal control and a bottle of ph reducer as well as small amounts of Dichlor. Question - do I need to empty / refill tub before adopting the TFP method or can I just shift to that - tub was filled on 6/6? Thanks in advance for your counsel!
Welcome to TFP! :wave: If you have a proper test kit (TF-100/Pro-Series or Taylor K-2006C) then you could validate if the water is well-balanced in order to leave it. But if it's questionable, you may have to start over. Did you do an Ahh-Some purge upon receipt of the tub? That should be step #1 for any new tube to get all the factory junk out of the lines. Did you see our article below? Look it over and let us know if it helps or raises more questions.
Thank you! I did not do an Ahhsome purge first - I didn’t find this site until I filled tub and added starter chemicals from starter kit. I have the TF100 Pro test kit on order and am accumulating other chemicals recommended here. I appreciate your suggestion of validating status of current water - even if it’s okay I’ll plan for a proper Ahhsome purge in very near future. Looking forward to learning more about spa water chemistry than I ever thought I’d need to know!
Reactions: Texas Splash
