After about 2 weeks of intensive research I made the dive (pun intended) and ordered my first "real" Above Ground Pool (only inflatables up to now). Ever since that moment we have been none stop leveling, clearing, collecting supplies, and praying for rain to go away. This post is long, but I tried to do as much research around these topics as possible before posting and here is the questions I could not find solid answers to.
I have some "background information" in between questions for extra information, but if you want to just jump to each set of questions I have numbered them.
Details:
- Saltwater 8000
- Solaxx Saltron Retro XL
- Hayward S180T 18" Sand Filter system with 1.5HP Power-Flo pump
- 25 Gauge Unibead Liner
We have also purchased:
- Cheapest Solar Cover I could find on Amazon
- Taylor K-2006
- Taylor K-1766 (salt test)
- Blue Wave Peel and Stick Cove
- 400 lbs of Salt
- 150 lbs of Filter Sand
- 20 Concrete Pavers
- Bonding supplies (100ft #8 with a bunch of split bolts and direct burry bolts)
Still to get:
- Limesand (for level skim)
- XPS 1" Tongue and Groove Foam
- GFCI box installed (electric already run)
The Plan:
I have dug about 18" on 3 sides of the pool and plan on semi-inground.
I will have native ground level within 1/4" on my wall line and 3/4" inside that.
I will then add Limesand for a final level and tamp it solid.
Foam Board on top of that, followed by my foam cove.
Still trying to figure out the backfill on my 18" hole.
The Questions:
Right now, we have the ground cleared and we have a 2 foot ring around the outside of the whole that is within 1/2 inch across the entire circle (using a transit to level).
Our next step is to remove the rest of the ground in the middle of the pool to make it as level as possible.
Here is where my first questions come from.
1) We are aiming for 1/4" across the 24' for level on the outer ring. Is this a typical tolerance? should we be trying for 1/8 or should we be happy with 1/2?
2) On the center we will be happy with 3/4" difference as long as its smooth, but my guess is it will naturally turn out better than this because of the outer circle as a reference.
After we fine level with Limesand and bury our patio stones, we plan on placing the foam directly on top. We are currently not planning on getting any "precut pad" we have no nut grass or anything we are worried about growing.
So, this leads me to my next question.
3) Should we have anything between the limesand and our foam?
4) Should we have anything between our foam and liner (perhaps to hide the tape seems)?
Once the pool is up, we need to bond the pool. I live outside of any city limits and in a county were there are no permits. I understand the purpose of these permits is for a safer experience and since my family will be swimming here for a long time (knock on wood) I don't really want to cut corners. Having said that some of these bonding requirements seem overkill, but I am open to being convinced otherwise. So here we begin my bonding questions.
5) Is the ring really necessary considering my pool will be only 4" above that 4' mark where these become necessary? My alternative would be a large grounding rod connecting the pool seam and all the electrical components.
6) I am burying 3/4 of the pool, so should the grounding ring be 4" below the top of the bury all the way around?
7) my SWG doesn't seem to have a bonding location, should I worry about bonding this, if so how?
This leads to my last set of questions surrounding burying the pool. My pool is covered by the warranty to be buried. But I am concerned about having dirt right up against the pool wall. I have a couple of options I am considering.
8) What should be directly against my pool wall 18" underground:
a) earth
b) concrete slurry mix
c) foam insulation board
d) black garden fabric
e) rubber mulch
Ok if you have hung in with me this far, THANK YOU! I can already tell this forum will be solely responsible for taking this pool from a 5-year pool to a 20+ year pool!
Details:
- Saltwater 8000
- Taylor K-2006
- 400 lbs of Salt
Still to get:
The Plan:
The Questions:
a) earth
e) rubber mulch
