Long time lurker, first time poster! I don’t close/drain my pool but I do winterize, as in I turn off the heater, add BioGuard Arctic Blue Winter shock and algaecide kit, Close the cover, and run the pump for about 3 hours a day (24/7 during a freeze--which is infrequent). Everything was fine for a long time... until this past summer.
In June I opened my pool to CYA way over 100. Did 3 drains and refills and CYA was still 90-100 so by July I gave up and ran the pool with high CYA all summer, sanitizing with cal hypo and using a lot of PH reducer. This month I did 2 more drains/refills and finally the CYA is now between 40-50. Water temp is down to 55. Still working on balancing (pH is 7.8, TA is 60) but once I do that, how do I keep chlorine in the pool all winter without having to open the cover frequently, which is a lot of wear and tear on the motor? Is it safe to pour bleach into the skimmer (with the filter on)?
Pool info:
16,000 gallons IG, gray plaster, Pentair Cartridge Filter
Pool install 2011
Taylor Test Kit
Pool info:
Pool install 2011
Taylor Test Kit
