Hello All,
Thanks so much for all the info here... and I'm going to immediately throw out my crappy test strips that really led me down the wrong path!
This forum has been so helpful with the pool school, pool math (and App!), etc... I just become a supporter... I'm sure you'll all save me more than what I donated! by a long shot.
I got the Taylor K-2006C (FAS-DPD) test kit.. read the booklet cover to cover, and am pretty confident in the results of this pool I just took ownership of and am taking care of for the first time.
I'll add to my signature when I figure it out again... but this is the pool:
~30k gal in-ground vinyl pool.
Sand Filter
2HP Pentair Whisperflow with 2" PVC (brand new - had it replaced by previous owners' and the pool's builder before I bought the house last fall)
Built in 2005 or 6 - doesn't seem to leak, but vinyl is very faded, as I'd expect I suppose.
Cleaning everything manually for now.. brushing and vacuuming.
Just opened a week ago, and I've been trying to balance it ever since with test strips. Well.. forget about that!!
Just got the Taylor kit and found:
FC 2.5
CC 3.0 (uh oh?!)
PH 8.2 (oops, thanks for nothing test strips!)
TA 90
CH 125
CYA 0 (dangit)
Temp 67F
CSI 0.17
Questions and confirmations:
Filter question:
Thanks all for the help.. really appreciating this place right about now as I ramp up my knowledge.
Sand Filter
FC 2.5
CC 3.0 (uh oh?!)
TA 90
CH 125
CYA 0 (dangit)
Temp 67F
CSI 0.17
- So with CC being 3.0 - Means I have a lot of things the FC is eating up... so I should SLAM? DiChlor good for this? Found it fairly cheap at Lowes.
- With TA 90, and PH 8.2 - just add appropriate muriatic acid?
- CYA at ZERO - Time for the sock in front of a return.
- If I add dichlor - do I also pour in some bleach? Unsure of the relationship here... just add dichlor, and when FC comes down again... and CC is zero.... start up with the bleach?
Filter question:
- I have a big sand filter.... from 2005'ish. Sand has probably never been changed.. who knows? Owners didn't do a lot of maintenance on this house... so now I'm bringing everything back to where it should be.
If I brush and vacuum.... but next day I see the pockets and swirls of dirt everywhere on the bottom again.... filter sand needs changing?
If so... where do folks usually by the many large bags of POOL SAND... pool store here seems very expensive to me.
