- Jul 20, 2017
- 233
- Plaster
- Pentair Intellichlor IC-60
Hi All - Had a Gunite pool built last summer and pool company did everything. I also have a hottub I inherited when I bought my home. I've put off learning about the chemistry side of things, until now.
From everything I've read it seems the TF-100 test kit should take of almost all the tests I need to do?
The hot tub right now is a bit cloudy and color is a little off. I've read about using Ahhsome to purge it and then refill with water and adjust chemicals as needed. Should I SLAM it before I do Ahhsome?
Separately, the hot tub sees almost no use during the summer months. I can put it on Sleep mode, which will keep the temp around 70F or so. Is this recommended or should I really drain it and turn it off until the fall?
Thanks in advance for any help or guidance.
