- Jun 25, 2021
- 28
- Vinyl
- Hayward Salt & Swim 3C
Hello I’m a new pool owner & also new to the forum, hopefully can get some help! We recently just moved into our first home with an in ground pool and I’m having issues with the vacuum. All the pool equipment was left by the previous home owner, and the first time I vacuumed while opening the pool there weren’t any issues. Now every time I go to clean the pool the vacuum hose will collapse (kink) just above the hole inside the skimmer. I’ve tried vacuuming on waste & regular filter but the hose will collapse every time. I tried backwashing first but that didn’t help either. Does anyone know why the hose would collapse? Is the hose just poor quality and I should buy a new one? I’m just diving into the pool life so really not sure how everything works yet. I have a Hayward pump & sand filter I believe. Any advice would be appreciated. Thanks all!
*Update Sunday morning*
I was able to switch the hose ends around on the vacuum head (was just on there extra tight). I tried to vacuum again this morning & success it worked! It also rained last night and dropped the temp of the pool to 26°C, when it usually sits around 30°C. Not sure if switching the hose worked or the cooler water temperature?
